Oil From Spark Plug Drain Hole??
I have oil coming out of the small hole in the side of the head that drains moisture from the spark plug area. I have replaced the o ring seal at the tappet cover (top of the spark plug tube) and still it comes. Any suggestions? Thanks
Either you damaged the spark plug tube seal again or the tube is cracked.You must put the seal on the tube and lube it up well with something slippery and then put the valve cover down.Not the other way around.hope this helps.cheers
