finally
I am a newb to computers but The Weez came through on the clutch :cry:
So how are you guys keeping the air boxes clean. I am going to run a PC Pro Seal but first I had to wash the sand and grease out of it. I don't mind doing this a couple times a season but there has to be a better way to clean the thing when it is on the bike. Thanks Weez. :cry:
I've never seen an X so naked!!
Twin Air (and other companies) makes an airbox cover that you install in place of the air filter that allows you to hose out the airbox while it's on the bike. If you have an R or an X with a modified airbox, pull the seat and you can get it squeaky clean in there.
Can you use it if you run the Pro Seal?
Since the ProSeal mates to the filter and the air box cover has the same profile as the filter, they should match. You're ready to rock :cry: !!
