Clutch Basket Weeble Woobles
In checking my stock 04's clutch.. I found the outer basket to feel loose (wobbles side to side and very small amount clockwise/counter clockwise movement). The inner hub feels fine... nice and tight.
Both basket and hub are in good shape without groves and I have not had any cushion material in my oil... So I would not normally replace them at this time.
Do I have cushions going out or is this normal "cushion" slop for an 04?
Thanks,
Youve got a problem...I dont care who you talk to about what, the clutch basket isnt supposed to wobble unitl youve thrown it on the bench... :cry:
Time to dig deeper and find the issue.
Thanks..
I forgot to mention that I have all the clutch disks and plates removed when doing the wooble test... if that matters..
Could it be the inner bearing / collar race?
I was trying to avoid pulling the whole right side case / water pump etc. off...
