the cyliner head as a trash collector
i removed the cylinder head off of my XR4oo last night. for lack of a better word, it looked like a buch of "dirt" had collected in there. you're probably thinking that a bunch fell in there when i removed the head cover, but the bike was clean and i was very carefull when removing the cover.
some of the stuff was black, and i concluded that it was either carbon or valve train particles.
some was brown.
i have also checked the down tube screen, and that only yielded 2 or 3 small metal flakes, but was otherwise very clean. i also took apart my last paper oil filter and it also clean.
have you guys experienced this in your engines?
I wonder the oil change history?
Maybe you want to flush the engine. A few oil changes with a chemical flush although the chems may hurt clutch.
I was thinking of auto engine and there are a few types of flsuh.
Maybe just change oil a few times or tear down entire top end and clean all parts by hand. You could do a top end rebuild with chains/tensioner/cam/ piston and rings and be like new.
Mark
in a month of ownership i've already put ~400 miles on the bike, and changed the oil 3 times. although there's no telling what the previous owner did or did not do for maintainence.
i noticed there was a plastic "chain guide" (?) near the cam chain. maybe the chain is slowly grinding pieces of this plastic away.
the cost of destroying a clutch from chemical flush is probably better than leaving the particles in there to float around. i'll take the cover off again after a few months and inspect.
MAR make good points:
You say you removed the cylinder head. Or was it the rocker cover? That's what I thought and figured you were looking at some oil residue buildup.
If you took off the head and were looking at top of pistom then that would be carbon.
Hey, if it's running good change the oil and clean the screens and run the heck out of it. If it has a little internal noise don't sweat it. Make sure valves are adjusted.
Mark
I hope this isn't a hijack, but you guys are screwing up my brain. Here I think I am just starting to get responsible, maintaining and making easy mods, re-jetting to bring up the performance ( I have absolutely no bog/ flat spot now - dumb luck) and you say I should dig a little deeper once every year or two. I have never even heard of the screen or tube and haven't yet even changed the oil filter. I have had the bike out for one rideable weekend up here in Alberta having bought it in September 2004. But if you're right, I need a new checklist telling me what other routine maintainance some of us retentive types should do. This stuff isn't in any of the sticky's or in Hairy Scary's excellent piece. And it needs to be a little simpler instruction for us rookies. Is Mar right about the need to do this? How long would it take?
Thanks.
Tedd
...I mean how many people do you think pull the Fuel Strainer Screen on the XR's?
haha i did that the first day when i removed the "varnish" from the tank!
i havent actually removed the head to inspect the piston and cyl wall...just the head cover where all the rockers and sub rockers are.
Thanks.
Tedd
you should check out http://www.g2-innovations.com/gentech/manuals.htm for a free xr400 manual. its in pdf form (100megs!) and it will tell the proper service intervals.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
