how to change air filter on 01 ttr 125
this may sound stupid but we bought a ttr 125 that didn't have a manual and we want to know how exactly to get to the air filter, i imagine u have to take off the seat like any other bike , but just so my dad doesn't do something stupid if someone has any info it would be appreciated
On the right side (rear brake pedal side) there is a toolless screw at the bottom of the number plate turn it counter clockwise and pull plate off. Then you will see the air box just unhook the rubber strap and the side of the air box will come off. then your filter will pull (slide) out away from the bike takes about 20 seconds. Hope this helps.
If it's like my '04 you pull the right (kickstart) side panel and the filter slides out the right side of the bike still attached to the filter plate. If you look at the pictures in this link you'll see the filter plate (base assembly) that slides out the right side. It does not come out the top.
Filter Base Plate
