exhaust gasket
I wouldn't do it. What if you burn up the valves in the process. Maybe use some asbestos gasket material cut to size until you can get the gasket.
In a pinch I have used high temp RTV on car header flanges and it
seemed to work ok.
I think I saw FFR suggest a peice of solid copper wire in some thread quite a while ago. Something about the stockers squishing out into the port.
I know you can anneal aluminum with a low temp flame to make it softer. You might do some research and see if it works for copper. Might make it easier to get a good fit.
i found a shop that matched one up this morning,it still has a slight leak but it will be enough to breakin the new topend and get it all checked to make sure all my clearances are good.honda gasket will be here in time to hit the track :)
