to weld or to bolt
I'v ebeen eye balling a scott's steering damper for a long time and finally decided to take the plunge. I have one question. Should I go with the weld on, the bolt on to where the dipstick goes, or the bolt on that goes around the steering stem.
Does the weld on interfere with the dipstick? How about a tempurature guage?
Does any one have problems with the bolt on coming loose?
Thanks guys
The only reason I have not done the stabilizer is that I was told the post does get in the way of the dipstick removal. If they have the steering stem post, that sounds like a much better install.
have you looked at WER dampers, they have a different mounting system the damper is mounted over the front fender.
The last time i looked into a Scotts the mount clamped around the oil fill neck, even if the dipstick is hampered removal of the clamp takes a second.
To answer your question, it may be less prone to braking in crashes if it was clamped on rather than welded .
Is there a particular reason for the damper?
I ask this because i almost bought one , and after talking to a few riders who raced and used them , they had one point which i took rather seriously, i ride in rocks mostly and go fast enough as it is , putting a damper on prevents sudden deflections , so far this is great but your speed increases as well, this combination make for a major crash if you make a mistake, sooooo with that said i decided NOT to install a damper
stu
I just got mine from scotts. Talked to a verry helpfull guy there. They hooked me up with the "forward" mount setup. It uses a clamp around the head tube in front of the bars. Oil cap is still accessable. Puts the extra hardware out in front, out of the way. Way cool!!! I was told that this is the Team Honda setup. I would recomend this over the other setups. Very clean, full access to oil fill, moving parts out of the way. Overall, the fit and finish of all the parts are top notch, service was great, shipping was fast. If this thing functions on par with the service and quality, it should rock. I'll find out how it rides on Sunday. I can't wait.
The Scotts forward mount does not clear a stock XR's Only temperature dip stick. In order for it to work, I had the dip stick turned in a metal lathe , and had all of the flat faces removed. So now my temp guage is completely round. It's now harder to remove, but it still provides the temp info I want.
Regards.
Dale
Just curious, but why do you need a dampner for a XR ? What exactally are the advantages?
Thanks for the replies.
Stu, I'm REALLY slow so getting a little faster is not a bad thing for me.
DW2, that was what I wanted to know. I run a temp dip stick and would like to keep it on along with the Scotts.
The reason I chose scott's is because it seems dead reliable, adjustable on the fly, and they a are located 5 minutes from my house. I go there all the time for other stuff and the people there are really cool.
Kemp, a damper is like a shock absorber for your bars from going side to side. I ride a lot of rocks and sand washes. When you hit a rock, the bars get jerked side ways, sometimes hard enough to rip if from your hands and loosing control. The stabilizer keeps it from deflecting. It dampes the shock of the bars and keeps the bike tracking straight. It also completely elimitates headshake when you're flying down sand washes.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
