Storm Cycles Suspension Linkage
Has anyone tried this linkage that supposively "makes your bike handle much better"? Not that I dont like the handling of my yzf, I just was wondering if it had any truth behind what its supposed to do.
its supposed to raise the rear susp and put more weight on the front ,you can get the same result by lowering the clamps on your forks. :cry:
try 5mm first. there's two sets of lines on the fork tubes,bring it down to the second set. thats usually enough for most people but you can go more. keep in mind the lower you go the less stability you'll have at high speed. the second notch is a good compromise. :)
