05 TE-510 Break in Ride report
Who I am:
I'm a 6'5" 260lb 50 yr old average "C" regular weekend trail and woods rider and occasional MX poser (rarely). I ride in NorCal single track woods, some Nevada desert and lots of California open play single / double track areas too. I have been riding now 16 months. I ride every weekend. I'm coming off my 03 DR-Z400S which I have sprung for my weight and quite a few improvement mods on that bike, including some power mods like a Yosh exhaust.
The 510 break in ride: about 30 minutes in open play, hard ground, type trail riding. My comments from my admittedly newbie point of view:
The Bike is Ultra Light. Any honda/ktm/yamaha posters who say the 239lbs Dry Claimed weight on Husky's web site is bull, well let me tell you those guys are FULL OF IT. THIS BIKE is LIGHT. and centered low-mid range, not as ground sucking low as the KTMs but lower and more even then the Yamaha WRF.
the 510 is FAST...did I say fast. I mean Holy Batman FASSSSTTTTTTT. The first 1/8th to maybe 3/16th of the throttle is great, then dare to roll that throttle just into the beginning of the meat and this Husky becomes a Ferrari. Man look out it's Happy time.
Suspension is set up Stiff......the bike felt better on the MX track. The bike has me out classed as a rider. The TE-510 could do triples in it's sleep. I will definitely have a shop re-do the suspension for me and serious trail, woods riding with sections of rocky, ruts and roots ..that bike would not float and dance up a rocky trail as it is set up stock.
The seat was slippery at first, plus I had new ride pants on too. I definitely will want to raise the bars as I am tall and standing could use some more height, but they are not bad at all stock and in the forward posistion. I love the feel and bend of the stock bars. I will want a Stabilizer because this bike is wicked FAST....did I say that alleady?.......Fast n Furious! :)
I got used to the kick stand..but would like to modify it so it doesn't jump up so easy per Flame's mod. The Motor and tranny gearing is perfect in my view, the stock sprockets are just right......the controls are good.......I will raise the forks a notch in the clamps as they came all the way extended.
Jumps: the bike FLYS. I can't wait till I start to feel fully a part of this bike. It is new to me..but I jumped it ever so small on the MX track and was AMAZED at how It can FLY...this Wolf has wings. It felt like I was a teenager jumpin a 125......I held back but I look forward to taking flight again.
ok that's all I have for now. Time to go change that factory oil, filter and clean the screens. YES THE BIKE IS AWESOME and wicked fast. POWER, Speed and grace......well more GRACE after I do the suspension for me.
how was the power compared to the wr450 you rode not too long ago?
the TE-510 power was definitely more manageable down low then the WRF. I never ran the WRF. I was more cautious as it wasn't my bike. so I can't compare the bikes much beyound 3rd gear......also the WRF only has 5 gears.. :)
The Husky is smoother power delivery then the WRF..the WRF is more torquey
THE WRF is a Potato Chopper...the Husky is a Cucumber slicer.
I attribute this to the larger bore/ shorter stroke design of the Husky.
MorningRider, sounds like you need a GPR version 2 dampner. It will raise the bars up with the mounting and you can keep the stock bars because you like the bend. Hope this helps.
MorningRider, you can fix the kick stand easy.
The stock setup sucks unless you like dropping your bike. The spring hits the bolt causing this Auto-fold action.
Cut off the nut portion of the bolt flush with the part of the bolt that widens, as the wide part keeps the kickstand on. Now cut in a slot like a flat blade screw driver in the top, check it with a screwdriver to see it fits. Now file off any burs paint and re-install with a screwdriver and must locktite. Will now work like a real kick stand!
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By Dean.b
      Long story short I bought this 2011 WR300. The thing is mint, looks brand spanking new. The thing ran like a top, but only had one problem, a low idle. I was to lazy to fix it and just dealt with the fact that I always needed to keep a little bit on the throttle. My third ride on it, I took it to the florence dunes and the top end burnt up. I have just finished fixing it and all I need to do is break it in. I need to adjust the idle first though, and don't know if I'll have the idle too high until it starts. I don't want to hurt the motor on a fresh rebuild and want some opinions on what to do. Do you think it will be fine? How many turns out should I set the carb just to be safe?
      Any response helps
      -Dean
    • By dorilabo
      #Husqvarna
      #CR125
      #2-Stroke
      #Maintenance
      #Advice
    • By motoxtremist
      Just bought a used 2017 Husqvarna FC450. It's my 1st EFI bike so I'm hoping someone can help me out with this issue.
      After starting the bike cold and idling for about a minute or two, it blows a puff of blue smoke from the exhaust pipe if I roll the throttle. It also does this if I stop to talk to a riding buddy on a trail or on the side of the track, let it idle, and then start out on track again. After revving it once the blue smoke is gone but riding buds have told me they smell and occasionally see a puff of blue smoke when following me - not a constant stream just a puff and then it's gone for a while. I'm talking to myself over trying to locate the cause of this as a leak-down test shows no issue.
      Bike history
      Bought used with 70 hours on it.
      Original owner had an FMF header and tailpipe on it which he kept. He sold it to me with the stock pipe. He never had it remapped for the FMF pipe
      Started it's life in Atlanta GA
      Now mostly ridden at sea level
      He told me he used mineral-based 10w-40 Yamalube oil. The manual calls for 10w-50 Ester-based synthetic - which the bike is now running.
      This is what I've tried so far:
      Leak-down test produced only a 3-5% loss.
      No bubbles in the coolant with the cap off
      No air leak at the exhaust pipe
      No leak at intake
      Barely, barely noticeable hiss when I remove the oil fill cap - but again not enough to lose any more than 5% pressure during the leak-down test.
      Wouldn't matter but checked the valve clearances while the valve cover was off. They were in spec.
      No loss of power
      No milky engine oil from a coolant leak
      No loss of engine oil as seen at the engine oil level window - never needed to add oil between changes
      Talked to someone who builds motors for a living and he said "all KTM/Husqvarna's do it especially when cold because the EFI delivers more fuel on startup as opposed to running at operating temperature". I guess I can see that but why does the bike blow blue smoke at operating temperature then if I pull off the trail or track for 1 minute to ask one of my riding buds something? I'm not letting it idle for minutes at a time. 1-2 minutes tops. Is this just normal for KTM/Husqvarna/4-stoke racing bikes?? Any help would be greatly appreciated!  Former bikes where 2-strokes (CR250, RM125) and a 1993 DR350 which I could've let idle for 20 minutes an not seen blue smoke - but that was a carbed bike. I've always known if a 4-stroke is smoking blue it's burning oil and you shouldn't keep riding it. So I'm a bit concerned about whipping it around the track or taking it out a few miles on trails.
    • By MotoXRacer_19
      As the title suggests, I've been debating the idea of throwing in a high compression piston. It will bump the compression in my 2014 KTM 350 XC-F from 13.5:1 to 14:1. First and foremost my main question is, because I live under 1000 ft and usually run 97 octane REC gas, will I have to change the fuel I run or not? Also, will I have to change out the cams to aftermarket and re-time the whole motor and ignition? I guess I really don't know what to expect so any advice will definitely help! Attached below is a photo of the bike I plan on putting it in.
