Headlight/ horn switch loose
I noticed my headlight/horn switch assembly spins easy on the handlebars. I didn't have time to really check it out before I put it up, but I did notice that the assembly halves are tight together. Is there a set screw inside. :)
Mine are nubless too, after installing Renthals. Mine don't move much, but some others have just put some electrical tape around the bars.
Ah..Isee. Thanks for the quick replies guys I'll get at it in the A.M. :)
When installing aftermarket bars on an S measure and drill holes in the bars where the old holes were. No rotation of controls after mod...DS
Don't think I want to be drilling holes in aluminum bars. Potential fracture point. The manufactureres worn against doing so.
Nubless works fine, and besides, allows to rotate the bars and housings if not just right.
I have an old inner tube that gets cut up for just such purposes. It has more friction than electrical tape so does not need to be so tight to not spin easily but when impacted it will turn.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
