Mx Race Prep
If muddy, spray fenders with pam or something. Tighten spokes, gas it up, check fuel valve on, change plug to a new one and make sure it is working properly. Check all hoses and lines. Check coolant, brake fluid, get sag set correct right before the race. Get contols set to your liking. Look at how the jumps are effecting poeples suspension and set it a couple clicks up or down on the compression. Check chain tension and that it is lubed up. Make sure the air filter is clean and there is not a lot of dust or clumps of mud in the air box. Check suspension for leaks and all bolts if you can for correct tension. Check tire pressure. Check oils and make sure the footpegs and pedals work properly and that are not packed with mud.
I hope this helps. :)
