Shock spring for an 04X
I'm going to change my shock spring and need some help on taking the spring off the shock,not to screw up the rebound clicker.Any help will be appreciated!!
Loosen the 2 top collars all the way. Slide (tap) the bottom part (spring seat#34) that holds the spring and you'll see a clip (#24). Remove the clip, slide #34 off and remove the spring.
