How Much do i shave off the head?
Im getting my head ported and polished and i want to shave the head to increase compression a little bit. Im not to sure to waht ratio, but almost to the amount a high compression piston would add. How much do I take off the head? About what ratio will it give me? Thanks
What type porting are you having done? Polishing :)
If you can afford the cost of porting buy the correct piston. You can probably remove a few thousands off the head or cylinder but any more will only make the timing chain longer and/or move the valves closer to the piston.
