03-250F Intake Valves
I've found lots of threads discussing valve clearance, etc..I'd like to understand a bit more how performance may be impacted when running the intake valves .001 - .002" above spec limit. My intakes are now set at .007" clearance -vs- the manual saying not to exceed .006"....Setting them to .007 was the only way I could get all three valves with the same clearnace. My assumption is the bike will run better if all 3 intakes are set equally. Any advice as to how this would impact my bikes performance?
thanks again!
