5 weight Fork oil level?
Can anyone tell me what height of 5wt oil they are using on a TE450 for woods/rocks/roots/occasional whoops? I weigh 185 pounds.
The recommended heights for the stock 7wt are most likely not applicable?
I remember they had me use 5wt (7 Stock) in my revalved Zoke conventional forks when I had a 99 KTM 200. Height was 100 mm.
Just trying to get a rough baseline to start with
04 TE 450 (Ridden twice due to injury)
Thanks,
Chris
Definately try 5wt at 100mils as the baseline then you may find you want 110 or 120. I was in the same scenario as you.
