Engine assembly question
I'm installing a Hotcams into my engine this coming week and Hotcams says to use assembly lube liberally. I have a Honda product, but it has Moly which I know is not good for wet clutches (which is in an XR400". If I use the lube with Moly will there be any problems? What other products have you guys used when rebuilding top ends?
i have a Hotcam, no special requirements i poured 1 cup of oil through the valve adj cover just to make sure it had oil when i fired it up, as far as assembly i used anti seize on all the bolts never had a problem,
run reg motorcycle oil to do the breakin, then you can go back to what you were using . Semie or full synthetic,keep away from moly as you know,
you'll enjoy the cam, :) it wakes up the motor a bit.
stu
