Changing the offset on a CRF250 '05
Would the '05 benefit if I mounted upper/lower clamps with 20mm offset? Or is it an unnecessary mod? I know they work well on the '04 model but since they moved the axle 2mm on the '05 I don't know if it still is a good mod.
Has anyone here tried a different offset on the '05?
If you are after function and the ability to change your steering in a few minutes to different settings, I would check out the CRF link that Fastway performance makes.
I have one on my my X and its pretty sweet how it completely tightened up the steering to honestly a thread the needle turner.
Neat thing about the Fastway, is you can change it back or to different settings with a different insert they provide.
I did a write up on my mine and here is the Fastway Link.
http://www.fastwayperformance.com/fastwaycrflink/
Now if your just into changing the looks through new tripple clamps...thats something else.
HR
Who cares....just buy it....it looks good on the bike :)
I care if my bike handles good or great. Yes I believe 20mm is the proper offset for 05.
I have the 20s from RG3 on my 05. They work great in the tight woods. Took
a few rides to get used to, but that bike will dart in and out of the tress
in the tight stuff as good as any bike I have ever ridden.
22mm offset for the 05's, 20's are for the 04's.
OK I knew they made a 2mm offset change for 05, I just had it backwards.
