Lower stack height, tapered or roller?
alright you xr100 gurus. i have a kx80 front end(with a xr100 steerer pressed in the lower triple) on my xr100 and the steerer tube is barely long enough. what has a lower stack height, roller or all balls tapered? thanks in advance.
They will be the same as the later rollers are a direct replacement for the ball and cup setup. The rollers actually go into the stem whereas the balls were out further.
