Boyesen Quickshot accelerator pump cover
No need to. Bike is running perfect.
Once it is warmed up, it will NOT bog under any condition.
And like someone said in a previuos post, a $5.00 #55 leak jet
will probably give the same results. 🙂🙂:p
I had used one from factory R&D.It actually made the bike bog.These things are supposed to get rid of a bog if you have one.I did not but wanted to try anyway.Maybe the boysen is different.
speedfrk is right. If you own a CRF250R and it has a bog off idle, try the CRF250X leak jet (the 49-state model, NOT the Cali model). The 49-state X has a #55 leak jet in it. The smaller jet will actually supply more gas to the accelerator pump squirter. The R model usually gets it's bog because it's not getting enough gas to the squirter. It has a #70 leak jet which "leaks" gas back into the float bowl and away from the squirter. The Cali X has a #65 leak jet.
While you all wait for the Boyesen reviews to come in, go buy the smaller leak jet and see if your problems go away.
Chris.
I have an X with the 55 leak. I've rejetted, played with air screw, and it helped, but still has a fairly bad bog, so I've got a pump cover ordered. It has a money back guarantee, and I will test that out if it doesn't completly get rid of the bog.
I talked to the guy whpo builds CHM's supermoto race team motors. Apparently you can get the equivelant jet out of a KX250 and they have them smaller than 55. I am going to put one in my carb as soon as I get the rest of my parts for my top end in!
That is like a 45 right? Better than a 55? The 55 helped my bog a bit but maybe smaller would be better yet. 🙂
If you have a part number for the smaller jet, will you post it? Thanks.
