Big Gunn pipe burns -- need heat shield -XR80
There is no heat shield on the Big Gun pipe and my son can't keep a pair of unburned pants on his leg. Not to mention the skin that he keeps loosing.
Does anyone know if I can run that pipe wrap to protect and insulate his leg from the heat.
If it will help, can anyone theel me where to get it.
Any other ideas?
Thanks
I took the old heat shield and cut it down to work on my big gun pipe. I just cut it to my desired size, cut some spacers out of some aluminum stock I had lieing around, and held it onto the pipe with hoseclamps. Hasn't fallen off or given me any more burns since. I'll throw up some pics for yah' in a second.
Pipe wrap works great!
www.designengineering.com
Moroso also makes some.
Be sure to get 1 inch width, works better on motorcycle pipe's small diameter and tight turns. Secure the ends with stainless steel hose clamps. Makes you motor run much cooler, and no more burned gear!
Robert :)
