fat bars vs. reg. bars
ok guys im 6'2 ride a 04 yz 250f. i currently like renthal jimmy button bars, i like them a lot and there at the perfect hight.
so does renthal have a jimmy button bend in the fat bar style. and if i do get fat bar do i need to change the top clamp or can i just bolt it up to the bike.
also what are the PROs and Cons of the 2.
thanks mike
Edit. i was looking on tag website and they have Cr double high and cr high. would that be the same as teh jimmy button bars.
Get on the websites and look the dimensions of the bars to see which one compare. (TAG vs. Renthal)
Unless your bike currently has fat bars you need adapters to make the fat bars work on your bike.
PROs of the fat bar are that are usually lighter and stronger and no crossbar.
Cons, no crossbar to mount anything to, ( GPS, or computer) more expensive and need adapters. If you are running barkbusters, you may need new mountings for those, depending on your set-up.
