CRF 250 head Flowed
I just finished flowing a 05 crf 250 head and it out flows the 04 head over the entire curve by a couple of cfm ,i havent had a chance to measure the portcross section down port yet, it still looks a little larger than it should be i will have to see if its close to the entry port area .the 05 head should be an improvement in power over the entire curve compared to the 04 head .
RHC
How does a modded 04 head compare to the 05. I remember you getting the 04 to flow very well after some putty work.
Mike
the moded 04 head out flows the stock 05 head by 7-8 cfm
...still waiting for my backordered 2005 head.... :)
Ron, will the epoxy ever deteriorate or break loose in the head? are there any possible problems with an epoxied head? thanks
Rich the 05 head out flowed the 04 head @ every point in .050" increments i made a special fixture to open the valves last year and it seems to produce repeatable results i also tested the head with out valves in it .the flow was a couple cfm better .the 04 head peaked flow @ .350" lift the 05 head continued to gain flow @ higher lifts a good indicator the air is folowing the short side better .
is getting an 05 head ported worth it? or is it becoming a waste because stock heads aare getting better and better.
