3x3 mod clarification
Before I start cutting anything ...
After removing the snorkel I now have a 3 5/8ths" by 3 5/16" opening behind the CDI. Do I also need to cut a 3" x 3" in hole in addition to the removal of the snorkel?
This is a CA E model.
no,you have a Cali E.once you take the snorkel out your done.
Thanks Burned. Glad I asked first. :)
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
