KLR 650 LED Tail Light!
:) Check this cool/safe light out!!! :p
This is the most important piece of equipment you can buy for your KLR 650!
Brake! LED taillights are brighter and more visible than traditional incandescent lights. Simply put, incandescent bulbs produce more-or-less full spectrum light (and a lot of heat) and filter out everything but red light through a colored lens. LEDs, on the other hand, produce a saturated, wavelength-specific light—in this case deep, intense red—without any heat or wasted light energy. This is why LEDs require far less power to produce light of equivalent brightness.
:) To further enhance visibility, the brake light :o strobes ;) for several seconds when the brake is applied, and then stays on like a regular brake light. It practically screams “Hey! I’m stopping! Back off!” Install a Brake! LED taillight and watch people stop ten feet farther behind you at the next traffic light. :D
Installation is a snap! Our KLR 650 LED conversion kit fits your existing taillight housing without any cutting or permanent modifications. You don’t even need to snip any wires; it simply plugs into the existing light bulb socket. Not only that, but you’ll never have to change a light bulb again. The LEDs we use are designed specifically for the automotive industry, and are rated to last over 100,000 hours without any visible degradation of light output. That’s like leaving your bike running non-stop for over 11 years. But that wasn’t good enough for us, so we designed the Brake! module to employ pulse-width modulation, meaning the LEDs are only lit 40% of the time in running light mode. So now you can leave your bike running continuously for 17 years, if you like.
Low power consumption!
Brake! LED taillights consume a miniscule 0.6 Watts in running light mode and 4 Watts with the brake applied. Compare this to the standard 5 Watt/21 Watt 1157 incandescent bulb. Some bikes even use two of those power-hungry bulbs—that’s 10/42 Watts!
This reduced power requirement eases the burden on your bike’s electrical system, which is important if you’re using additional electrical accessories like heated vests or our heated handgrips. Many motorcycles (particularly of the dual-sport variety) have very little electrical power to spare in the first place, so what better way to reduce power consumption than with a brighter, more durable and less power-hungry LED taillight?
Does your headlight dim when you apply the brakes? Old, damaged and/or corroded wiring is not uncommon on motorcycles. The increased resistance that results means there is a lower voltage (below 12V) reaching lighting devices. The Brake! LED taillight has its own voltage regulation, and can operate on supplies as low as 9 volts without any reduction in light output. And its low wattage leaves more power for the headlight.
KLR 650 LED TAIL LIGHT Part# 36-20500-000 Price: $64.95
DUAL STAR 1-800-GO-N-RIDE - 1-800-466-7433
:Dhttp://www.dual-star.com/index2/Brand/Kawasaki/klr_650_led_taillight.htm :D
I don't know if this is the correct forum for a Dual-star ad. Unless you were just posting the info because you have one, but it would be a more convincing opinion if it was in your own words instead of mostly copying the ad on the DUal-Star website.
That said, I had one on my KLR650 and though expensive I thought it was worth it. You can turn off the flash-on-braking feature with a dip switch on the board.
It was brighter than the stock incandescent bulb, but the one feature I liked best was it seemed nearly immune to vibration when mounted according to the instructions. I got pulled over by a NJ state trooper one night because my old tail light had burned out and I was invisible from behind. I got the LED bulb after that. This isn't one of those pop-in "1157" led replacement bulbs, it's a circuit board that fits the entire width of the reflector with a large array of LEDs. Bright and viewable from a wide angle behind the bike. I really hammered the bike offroad for a year and a half, never had any trouble with it.
Running draw reduced by 4w doesn't seem like much but if you replace the three instrument lights with white LEDs also, you'll free up a total of 28 watts, which is a set of electric gloves or grip wraps.
Hi Guys,
Just thought I throw in my tuppney bit!!!
Ebay has a proliferation of led tails lights (I have a couple on my bike) - but now there's a flashing version too for around £6GBP ($12USD).
Cheaper & easier to replace if necessary!
  • Similar Content
    • By Josh Munn
      Hi guys i recently bought a klr600 thats was running but had issues the guy i bought it off had fitted a manual timing chain adjuster but it had jumped a tooth and would hardly run i fixed that but it seems like the timing is retarded any one had this issue not sure what it uses as a pick up or if it has an auto advance. Cheers
      I also own a 81 xl185s, 81 xr250, and a 83 xr350. Cheers
    • By CantleyCustoms
      Hello guys,New to the forum.
      Quick question,I have a 1994 klx650c i recently purchased and am in the process of upgrading it.
      Have a trial tech vapor speedo ready to fit,however just wondering about the stock instrument gauges etc.
      Is it literally a case of unplugging the old dash and fitting the Vapor? Is the Dash used to complete the stock wiring circuit? e.g-if i unplug it and leave it unplugged is it going to effect the running of the bike? What about the dash lights,how would i go about wiring these up?
      electrics really isn't my strong point,got the basics covered but way too complicated for me.
      any help greatly appreciated,any more info you need please feel free to ask.
    • By rodrigonehme
      Hello, This is my first post and I'm new to TT.  I recently acquired a 2008 KLR650 (which by the way I absolutely love) and I'm working on adjusting my valves, I already measured its clearances and found this helpful online calculator: http://www.carguy.org/klr650/shims.html however I'm unsure of what the shim factory setting size is and it is essential to get the right shims. Does anybody know what the factory settings are?
      Thank you!
    • By RT_Chris448
      Recently we did a project bike with Dirt Bike Magazine's KLR650 and we were pretty excited about the results.  Check out the article on this fun project here:
    • By DougBurgoyne
      Hey guys,
      A super duper THANKS for all the help, laughs, and fun I've had here, and the bike I put together based on advice and lots and lots of reading material you've provided on what is the best vehicle forum I've ever encountered (been on many over the years). .
      Just when my bike was absolutely the bike I wanted it to be, my riding buddy (who is my father in law) bounced of his DRZ well up 4610 here in Oregon and broke his leg, and good. Tib/fib  job requiring rods, screws, plates, and a kitchen sink to put back together. If it wasn't for the MX boots I got him, and "forced" him to wear....there would have been all sorts of nastiness sticking out of the skin. No doubt about it, as both lower bones broke at sharp angles making spears inside his leg. As it was, everything was contained. He is going to be down for quite some time. I bought my drz to ride with him initially as he had a KLR650 and had an interest in backroad and moderate trail riding. On our first trip out (Brown's camp easy/mod trails) after about 10 times picking up his KLR with over-inflated 50/50 tires (mine stayed on 2 wheels all day long) he said "I need a bike like yours". Within a week he had his DRZ too! Then over the fall and winter we did all the mods and fixes to get them ready for this spring/summer.  It was kind of a miracle I even convinced my wife to let me get a dual sport bike. I'm 50 now, and have a degenerative vision disease called RP. Basically, I'm missing quite a bit of my vision field, but have decent vision straight ahead (unlike macular degeneration). I'm not in denial that good/full  vision is important for safe motorcycle riding on the street...and the reason I'm a 90/10 dirt/street guy. My argument was that we won't get hurt just poking around the woods, old man style, with occasional pavement work to connect trails (thus the need for dual sport over dirt bike).  Well, my father in law shot that theory down, but good!  He has dealt with so much pain over the last month, and met several dual sport riders in for riding injuries (some that make his look like a kid's day camp) that he decided he is out of the game. Unfortunately for me, that means I'm out of the game too. My wife is so worried I'm going to get injured badly, that it's not worth the fight. I don't want her and my daughter stressed and worried every time I go riding. My father in law was doing great on the roads and trails we've been riding. And just loved riding the DRZ. But he's 70 and looking at Jeep Wranglers with lift/tires for his forest adventures going forward. Not a bad call imo.  So...I've sold 2 DRZ's and a KLR in about 1 week (here in Portland OR, I could have sold 4 more DRZ's in the same time if I had them!).  His 1100 Honda shadow cruiser is on C.L. now as he is cleaning out the stable completely. Sad, sad day. It's only been a month since our last ride and I'm already missing the dirt big time. Even sold my daughters doodle bug. Oh well, life goes on.
      Take care guys, ride safe (inside your skill level), gear up...and have some fun for me!!
