Another Air Filter Question???
The owners manual says to use 10w40 motor oil on the air filter. I have used both foam filter oil and 10w40 and find the wetness of the 10w40 actually collects more dust and is easier to wash out with solvent. The question is why is the foam air filter oil more recommended..
the motor oil also doesnt stay in suspension and drains out of the filter.
use good filter oil.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
