Clutch Spring Questions
Could someone answer these questions:
1. original lenght of the clutch springs ( in / mm )
2. service limit ( in / mm ) it says in the manual 1.76 in / 43.7 mm, mine are 36mm!!
3. do the crf 450 springs fit into the 250?
I aske because my steel plates are heavy discolored ( blue means very hot ) and my clutsch slipps.
Thanks for any answer
1. I don't know...but they are too weak/light and sack out easily.
2. See above...it's not unsual.
3.Yes,,,along with the 250 2 stroke springs...and there are plenty of aftermarket springs.....all are better quality,won't sack out and provide better pressure on the plates. You can spend anywhere from $8(stock and Moose) to $60(ProCircuit).
My X clutch slipped on it's first ride. I replaced the springs with EBC springs and haven't had a problem since.I had them out recently and they were still at the same length after about 500 miles. I wish I could say that about my valves.
