Kientech Fuel Screw O-Ring
Hello all, I have received Fuel screw, spring, o-ring, and washer for my S model with Mikuni Br36, can some one give me proper order of intstalling these items
Thanks in advance 🙂
To calrify point of reference: If you have the fuel screw in your hand, put the spring on the screw, then the washer, then the "O" ring. Then install that assembly into the carb.
If you start from the carb body, it is: "O" ring, washer, spring , screw.
