no-fog goggles???
hey whats the best NO-FOG goggles i can get for under 40$? ive tried my friends smith's (donno what model but they were 35$) they worked good. anything better? thanks
Just use some scotts no-fog cloths on any ol goggles! 2$!
Personally, I never had any luck with the no fog cloths or sprays. I recently replaced the standard lens in my ProGrips with the dual layer no fog type, and I am impressed with how well it works.
Other brands make these lenses as well. Look for a lens that has two layers, maybe 1/16" apart and seperated by foam around the edges. 🙂
I have the Progrip no fog goggles and the film or the sheet is starting to separate from the lens 🙂 . It is bubbling away. Now the sun hits it and impairs my vision substantially.
A lot of guys I ride with like the Scott Turbo Flow. It's basically a two lens setup with venting at the top of the front lense. If you run tear-offs, you have to cut the top of the tear-off so you don't cover the venting. I've seen some 'tards who think they don't work, but they've been covering the vents. Anyway, I don't think they'll save $$$ though. Nothing seems to work perfect though when it's like 68 and a 95% relative humidity.
My two layer Scott's work great for not fogging, but if you get water or mud between the two layers, it sucks to clean them.
I have had this happen to several lenses for my Pro grips I finially threw the entire thing away. Junk I say.
I now use the dual layer vented lense for my Oakleys. That with No fog cloths seem to do the trick.
