Torque Specs
Can someone please give me the Torque specs for the following:
Lower and upper shock bolt
Subframe bolts
rear and front axles
steering stem bolt
Its an 04 250f and I dont have a manual.
Thanks, but I am still on dial up and that would take about 3hrs to download. Can someone just ck their manual and let me know the specs on those specific bolts...Please!! 🙂
Hang on a sec. I will get you some specs. Please disregard what I just posted. I was in the wrong book.........
I do not have an 04 manual handy at this time. I do have a manual from an 2002.
Stering stem:
Lower nut (under top triple clamp) - 27 ft/lbs, loosen 1 turn and retighten.
Upper nut (about the triple clamp) - 105 ft/lbs
rear shock:
upper - 40 ft/lbs
lower - 38 ft/lbs
Axles:
front - 75 ft/lbs
rear - 90 ft/lbs
subframe:
top (one bolt) 21 ft/lbs
bottom (two hex) 21 ft/lbs
Thats better. Like I said this is for a 2002 model. They might be a little different. I would think that they are realatively close though... Hope this helps 🙂
