?? about ttr225
i was ridding down the trails one day and it smelt like rubber burning so i got off my ttr225 and was looking at it and the muffler was rubbing on the tire and the now is i preety good hole in it... i checked the bolts and everything is tight has any one else had this happen?? but now i have to buy a new muffler so any advice on what to buy and prices??
You most likely crashed on the right side and bent the pipe inward. You should not have to buy a new muffler, just take it down to a local welding shop (high school, muffler shop etc.) and have them weld a piece of thin steal over the hole. Then reinstall the pipe. Then insert a big shovel handle between the muffler and frame rail and bend that muffler out of the way of the tire. Then it is as good as new(almost). If you want a new pipe for the bling factor then go for it. But I recommend going the cheap way and buying new tires and barkbusters(handguards) for you bike.
