New Toy for the DRZ
Now I just gotta get it wired into the battery..... BTW, would using some dielectric grease keep it from turning off until I get it wired in?
'scuse me, but are your barkbuster's inside mounts attached to the
triple clamps?
i don't think i've ever seen that setup before 🙂
looks clean
That does look pretty cool. Do you worry about breaking off the triple clamps bolts though? I crash a lot. 🙂
nice toy. :p🙂
I broke my old one and i was trying to deside if i wanted to replace it or get something else... I opted for something else. 🙂
Don't worry, the triple clamp mounts are sturdy!
Hardwire direct from the battery with an inline fuse somewhere for the GPS. Solder the connections and use dielectric grease at the GPS. Should be good to go! 🙂
It's turning off because the batteries are getting shaken around inside their compartment. Wedge some paper inside there to tighten it up until you wire it into your bike 🙂
what the heck is that Wolf? a helmet cam? I wanna see some video
Nice set up on the etrex. I have one and want a mount for it. Which one did you use?
Those are Cycra Pro Bend bark busters and they are sturdy, no worries about breaking them.
I have my E-trex mounted to a RAM mount, very solid!
Wolf, That helmet cam is all that! What did that set you back? I must consider that for some rides with my little one. She would get a kick out of watching our trail ride adventures! 🙂
which ram mount did you buy, how much and from where? thanks
I just bought the mount that is designed for the Etrex series GPS with the 2.5" arm. I had to buy a different ubolt though because the fatbars are to thick for the ubolt that comes with the mount, I did not have to modify the mount to accept the larger u-bolt. Here is where I bought mine...
http://www.ebatterytechmounts.com/
I used some thin foam weather stripping stuck on the inside of the battery cover to keep the batteries from shifting. I've never had them bounce loose yet.
Ditto on the RAM mount.
I have a legend as well, and unfortunately, it does not have the circuitry inside to reduce the 12 v to the 3 v used by the unit. You have to use their car adapter and install a socket on your bike somewhere to plug it into. What i did was buy a C battery unit to plug it into. Does not rattle loose and lasts way longer. You can get one here. I have heard of guys that have disected the cigarette lighter plug and modified it for a hard wire install. Call the guys at the link below and they can help you out. BTW, I really like the legend, it has never let me down.
Cycoactive
Hardwire info
Wolf child that's a nice job you got there in your helmet
:p🙂
How mutch did it cost and where did you buy that?
Does that use AA or AAA batteries lined up end to end? If so the trick to them is to place the batteries end to end (on the table not in the gps) like they would be in the GPS. But put them in a V with the ends touching. Then place a strip of black tape in the V holding the batteries together. Then when you straighten the batteries out like they are in the GPS it stretches the tape and keeps that center connection from vibrating apart and shutting off. Then on the outter ends were it touches the spring/metal tab dielictric grease.
ANother trick is to figure out were the batteries are under the cover and put little "hershey Kiss" dollops of Silocone under the batterie cover. Then when you snap the cover on the silicone "Kisses" will press against the batteries keeping them in place.
www.Cycoactive.com has all these tips on there site somewere.
http://www.cycoactive.com/gps/gps_batteries.html
http://www.cycoactive.com/gps/GPS_batts/gps_batts_eTrex.html
