4th clip from top
Got my DynoJet kit today. :) Just finished the install using a 140 mj (stock exhaust) 25 pj and 2.5 turns out on the fuel screw. I ride at elevations of 700 to 1000 ft., in temps of 45-90 deg. F, and humidty of 60 - 100%. I have done the 3x3 air box mod as well. I installed the clip in the 4th grove from the top (flat end) of the needle, but noticed something that needs clarification. I read in previous threads, that the picture with the DJ instruction sheet showed the clip in the 3rd goove. The sheet that came with my kit, has a picture showing the clip in the 4th groove (of 6 possible) with an arrow pointing to it. The wording stated "on groove #4 from the top" just as it apparently always has. My instruction sheet also has a set of numbers that appear to have been rubber stamped under the box labeled "Parts List." Those numbers are 34122704 in case they are of significance to anyone. Does anyone know if DynoJet corrected their drawing? Sorry if this is old news that I missed somewhere along the way. :)
The jetting that is recommended in theDJ kit is NOT for use with the 3X3 airbox mod.
Ignore DJ's jetting directions, and just follow Burned's jetting.
I think Burned would go along with what you posted...maybe he'll jump in here. What you describe should be about right for your elevation. Good luck...
So....how's it run?
You'll have to fine tune your jetting to your preference and your bike as not all are exactly the same. You've got it at the baseline now (140,25,2.5) but will probably find you have to change it a bit. 142.5MJ is getting alot of use lately, as is the stock slide spring. The A/F screw, people go anywhere from 2.5-3.5. You'll just have to test to see what works best for you. Good luck :)
Baseline settings will have to do for now. :p I could put the battery back in it and start it up tommorrow, but our roads have too much salt on them for me to give it a test. :D From what I've read here at TT, the vast majority seem quite happy with burned's baseline settings. :) I saved the stock 142.5 mj, and have the washer that came with the DJ kit should I need to use a 4.5 clip position. Tweaking it will be a snap, if I need to do it. :)
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
