which one?? xr 250 or crf 230? or xr 400??
hey, i was wondering if the xr 250 was underpowered??, would the crf 230 be a better choice? :) i am 5'7 135? i was also wondering if i should just step it up to a xr 400? if so how far do the years go back on the 250 and 400? thank u to anyone who responds to this cause i have no clue :)
You have a seat height problem more than anything. The 230 is the obvious choice for you, of the bikes mentioned.
Well, im 5'4(with short legs for a 5'4) and 130lbs. I have a xr250, its not too tall for me. I set the sag right, and just recently shaved the seat on it. Its not too tall at all, if you can plant one foot, your good. The xr250 is way more bike than a crf230, the xr250 has a lot more power, and i think a lot more mods. But if you are a novice rider, getting to learn, and want a bike you can whip around easier, the crf230 would be a choice. My friend rides a crf230, and he likes it, but i like my xr250 better, ive ridden his bike, the ergos just dont feel as good.
about the only advantage the 230 has over the 250 is electric start. The 250 has much better suspesion and more power. My dad rides an '01 XR400R and hes only 5'6 the seat height aint much of an issue for him except in the really knarly sections. Get the 250 put a lowering link on it set the sag and youll be good to go. :)
If you are a good rider, get a yamaha WR400. Or get the XR400, the XR is bulletproof, but the WR is almost as durable (and has about 20 more horsepower). The XR400 hasn't changed since 1996 or 1997. IF you like to ride fast, get a WR400, if you like it slow and technical, get an XR400. Stay away from anything under 400cc's, you will have to ride it too hard to go fast, and you will end up with a blown engine. Bigger bikes are going to last a lot longer without needing top end rebuilds. :) I have a riding buddy that is about 5'4", and 100 pounds, and he can ride my bike without a problem. If your feet can touch the pegs, you are good. :)
At 5'-7" forget the lowering link, you don't need it, plus I assume your still growing. If not it doesn't matter, you'll be fine.
The 400s have more power and more weight, two things you don't need at this point.
Learn to ride the XR2.5 to its full potential, you don't need a 400.
The XR2.5 is a much better bike than the CRF230. After the "Gordon's Mods" the XR2.5 is quite capable. In certain situations the XR2.5 will surpass the XR4, bigger isn't always better.
The Yammies are about 2" higher in the seat, forget about them.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
