Did a rebuild but now wont start
I just got done rebuilding piston,valves, and springs. The bike wont start. I think my problem is timming with the chain. When i was taking it apart i made a mark with a marker like everybody said on the chain and the gear. I put in back togeather with the mark i made. I took the chain tenshioner out so i was wondering if the chain can move or skip a gear down in the crank. It sounds like it wants to kick over but it wont. I know i put the valves it right and the springs too. Also the bike seems to have alot more comprssion that ever. Im possitive i put the piston and rings in correctly. What should i do. How would i know if the chain is off by a tooth down below, is there a mark or something. please help
Check the timing marks on the inspection cover on the clutch side and the marks on the cam gear and head. The manual covers this.
It can skip a tooth on the lower gear.
the bottom inspection hole behind the cap with the hex in it has two gears you can see theirs a dot on each line them up.
your cam sould be lobes up and your cam wheel on the end of the cam has two flat lines that should be perfectly parallel with the top of the head you can bet your out a tooth. recheck this then kick your bike over slowly a couple of times and then recheck before you put the valve cover back on.
easy peasy.
thiers apost on this site somewhere with pictures that will be of value to you if your still unsure.
good luck
It's a sticky thread on the top of this forum.
Make sure the cam chain is on the lower gear.I just got done with a rebuild about 2 weeks ago and it happened to me.My fault.
I just checked and the lobes are facing backwards and the lines on the gears are lines up to where the top of the case is. and the t mark down by the cluch is lined up. How will i know if the chain is off the gear down below in the case. do i need to take the whole left side cover off.
when you you kick the kick start do you feel some pressure come out of the silencer.if yes it is fine if no it is probally off.
Well Ive never rebuilt one before but id have to say the easiest way would be to pull the valve cover and slowly turn it over and see if the chain starts to move, then you know its on both gears. While your in there slowly kick it over and visually see how the valves are working. I would hold down the shut off button while kicking it over to check things, theres not much if any chance it could start kicking it over slow like that but id rather be safer than sorry.
There is compression coming out the pipe but its really hard to kick. I bet it got off a tooth in the lower gear. So how do i get in there to change it and what do i need to look for. is there some kind of mark. Some body has to know. i dont want to take it to the shop. Is ther any way i could have put in chain tensioner in wrong or backwards.
The chain may not be "Off a tooth" so to speak but it may have got a loop of chain down there so there is an extra tooths worth of chain hanging around down by the crank sprocket. But usually when that happens and you roll the motor over it will correct itself. But by correcting itself it will throw the cam timing off so you have to recheck it again. Roll the motor over several times then recheck your timing. That is my advice.
That or turn the gas on :)
If i keep kicking it over you say that the chain down below will atomaticly realign itself. i dont think so. but ill try.
Unless the chain guides are so tight against the chain that it cant pop past them I think it will.
Think of it like your rear sprocket. If you wrap the chain around it but pull a small loop of extra chain about half way around the sprocket. As you turn the wheel the extra loop will roll off the sprocket and right itself. At least that is how I see it.
Like I said unless the chain guides are preventing this.
If the chain is on and you say the timing marks line up with the lobes facing towards the back then it should start.Make sure your at tdc.Open the cap that shows timing gear.Make sure marks line up then the marks on the cam gear should line up with the head (there are 2 marks) with the lobes facing towards the back tire.This is the proper timing setting.
Note - most people call the small metal assembly that bolts to the side of the cylinder the chain tensioner. It's not the chain tensioner. The chain tensioner is the flexible black plastic piece that fits inside the cam chain tower and pushes against the chain. The metal assembly is the tensioner lifter assembly. See the Honda parts manual for part names. I suppose it will continue to be called the chain tensioner, anyway.
You can check the "chain tensioner" as follows:
Page 8-9 of the Honda Service Manual, '04 & '05 XRF250X, shows:
Remove the cam chain tensioner lifter bolt and sealing washer. (Rick's note - this is the 8mm-head bolt in the center.)
Turn the cam chain tensioner lifter shaft clockwise fully and secure it with the special tool. (Rick's note - use a small screwdriver and hold it in place with a pair of vise grips attached to the screwdriver handle - let it hang.)
Rick's note - Now, with the spark plug removed, but connected to the spark plug lead and the plug grounded to the frame or engine so the electrical system doesn't get a stray zap, kick the bike through slowly with the kick starter. The engine should turn over fairly easily.
If the engine turns over easily, you probably had the tensioner lifter assembly extended when you installed it and it was binding up the cam chain excessively. If the engine still does not turn over easily, you have another problem.
The alignment is done at the top; the lines on the cam gear aligned with the cylinder head surface. The lower gear has no alignment marks. You only need to get the alignment correct at the top.
Of course, the crank gear must be aligned to the index mark on the case (inspection hole near the clutch) and the piston must be at TDC on the compression stroke.
This is not possible if the cam chain is over the cam gear; there is not enough slack for a loop or excess chain anywhere.
Take the cover of the left side and be sure the chain is on the crank gear. There is a little metal tab under the gear to keep the chain on the gear but if you rolled the crank with slack in the chain it will come off and lodge between the gear and tab. While your in there check the screen in the lower rear of the case and clean it. Be careful putting the cover back on as there is a seal in there that seal on the end of the crank to provide oil pressure up top. Let us know what you find.
Here's an idea. Take it to your local shop and have it looked at before you blow up your brand new "rebuild job".
I have all the timming marks lined up. And the mother wont start. I accidently was trying to start it with the chain tensioner thingy out and it almost started. When i put the tensioner back in it had like doubble the compression. Also i checked my valves at TDC. My exhausts were in speck but my intakes have no space to put any thing under. If my intakes went to zero wouldnt it have like no compression. I cant think of any thing else. I drained my carb, new plug, and there is oil in it. I have gas too.
You're installing the "chain tensioner thingy" incorrectly. If you had done what I advised, you'd be done now.
It is super easy to make sure you have the timing chain on the correct teeth.
Pull the valve cover off.
Pull the spark plug out.
Place a long screwdriver down the plug hole.
Slowly turn the motor over w/ the kick start until you are at exact TDC (doesn't matter what stroke you're on.)
Now look at the hash marks and they should be EXACTLY lined up w/ the top of the head. (Again, doesn't matter whether the cam lobes are pointing to the back or front, because 180 degrees later you will be at EXACT TDC again)
If the marks aren't lined up, just remove the cam holders, tilt the cam down, and move the sprocket to different teeth, so that the hash marks line up.
Man, I wished I had figured that system out myself, it's brilliantly simple.
Pete
  • Similar Content
    • By Kadensmith44
      I’m wanting to powder coat my bike but it’s all new to me. I’ve got a powder coater picked out that I’ve heard is good for what I’m doing. I’m not 100% what kind of sand blaster I need and what kind of media. I have also heard you can’t cook in the oven after you’ve baked your parts is that true?
    • By luke8500
      Hi all,
      I have a 2004 honda crf250r and it wont start hot at all. The motor was just rebuilt with a new cylinder and piston. The valves were just adjusted. It will start cold in 1 or 2 kicks with choke but as soon as it gets hot it wont start. If you bump start it the motor will just turn over without starting.  sometimes it will start. It runs great until you shut it off.  im thinking its either a fuel issue or an electrical issue. Any help would be greatly appreciated.
    • By SandSoldier
      Hello! This listing is for my 2007 Honda CRF250R dirt bike. Last winter I spun the rod bearing and just recently finished rebuilding it. Selling to fund new bike. I am currently the second owner.
      Current registration valid until 2020, pink slip in hand.
      Fresh parts:
      -top end kit: Wiseco; forged, moly skirt coated, 12.9:1 comp ratio (new wrist pin, gaskets, etc)
      -cylinder: new OEM
      -bottom end kit: Wiseco; (new bearings, seals, etc)
      -oil pump: new OEM
      -head studs & nuts: new OEM
      -fresh oil and filter
      -all tolerances checked in top end
      -valves adjusted
      -carb adjusted
      Note:
      *rebuild was done by my dad (master tech at CAT) and I (4th year mechanical engineering student)
      *has maybe 15 minutes on new parts, IT HAS NOT BEEN PROPERLY BROKEN IN YET
      *I have email receipts, pics of rebuild, and old parts as proof of rebuild, just ask and I'll show em off
      Other parts:
      -90% tread on front and rear tires
      -excell takasago front wheel
      -custom aluminum skid plate
      -wrap around hand guards
      -spark arrestor
      -kickstand
      Feel free to ask for any more specifics or pictures!
      LOCAL PICK UP ONLY
      Thanks!
    • By Matt Ray
      Okay so the title is a little vague.
      So it was having trouble idling and even starting when I first bought it about a month ago for $2k.
      So I did a rough clean of carb, looked up on YouTube, Forums, Etc on how to do it. I only cleaned jets with carb cleaner and sprayed around the float bowl area and such, so not too extensive.
      Did that and I took it out to a park, It would start up right away mostly, few kicks sometimes, but when I got it started, I had to keep the choke on. Right when I was ready to go fast and go up to 3rd and 4th gear I'd switch it off and it would work fine and sound fine and everything, but when I slowed back down and coasted around 1st gear i'd pop it back out again because it sounded like it was going to do. I have some videos if people would like me to link to them.
      So after that I decided to take it apart and replace spark plug with OEM NGK R0409B-8, replace main jet from a old 170 to a new 170, replaced pilot jet from a old 40 to a new 42, and kept starter jet the same just made sure that wasn't clogged, ordered a new adjustable fuel screw and used that.
      and it was still having a little bit of problems! I just started up today and the day before today. It would run only with choke on, if i twisted throttle in neutral it sounded pretty good, no gun shot noises or anything, pretty smooth.
      If I tried to take choke off it would die immediately. So I started it back up again, took around 6 kicks.. So again with choke on it sounded like it was starting to lose power and RPM's would drop so I'd twist throttle a few times and it would stay idling.. then after a small amount of time, start to sound like its about to die again... so I would rev it up again, and repeat..
      Fuel line isn't clogged, flows fine.
      I tried fuel screw everywhere between 1 and 2 turns out..
      I checked valve clearances, and I'm no expert but from the videos I watched the slipped underneath intake and exhaust with only minor force.
      So I'm lost..
      Maybe float bowl is messed up? Should I just do a COMPLETE carb rebuild from videos I've seen on youtube, like this one -> https://www.youtube.com/watch?v=3AXb9UprT30? Or what?
      It's getting annoying taking it apart all the time, I jsut want it to start up quickly and run well!!
      Thank you!
      Austin, TX, Elevation 600ft, where I ride its around 900ft
    • By Bryan Bosch
      WASHINGTON, D.C. – August 16, 2018 – (Motor Sports Newswire) –
      Honda Recall Summary:
      Name of product: CRF250R Off-Road Motorcycles Hazard: The clutch outer can break, posing crash and injury hazards. Remedy: Repair Recall date: August 16, 2018 Units: About 3,200
      Consumer Contact: American Honda toll-free at 866-784-1870 from 8:30 a.m. to 4:30 p.m. PT Monday through Friday or online at http://powersports.honda.com/ and click on “Recall Information” at the bottom of the page for more information.
      Honda Recall Details:
      Description: This recall involves all 2018 Model Year CRF250R off-road motorcycles. The recalled motorcycles were sold in a red color. The names “HONDA” and “CRF250R” are printed on the sides of the motorcycle. The model name and model year are printed on a name plate label located at the front right top of the frame, near the steering head.
      Remedy: Consumers should immediately stop using the recalled off-road motorcycles and contact their local authorized Honda Powersports dealer to schedule an appointment for a free repair. Honda is contacting all known purchasers directly.
      Incidents/Injuries: American Honda has received 19 reports of clutch failure, including two that led to engine lock up. No crashes or injuries reported.
      Sold At: Authorized Honda Powersports dealers nationwide from November 2017 through July 2018 for about $8,000.
      Manufacturer(s): American Honda Motor Company Inc., of Torrance, Calif. Manufactured In: Japan Recall number: 18-759 This recall was conducted, voluntarily by the company, under CPSC’s Fast Track Recall process. Fast Track recalls are initiated by firms, who commit to work with CPSC to quickly announce the recall and remedy to protect consumers.
      The U.S. Consumer Product Safety Commission is charged with protecting the public from unreasonable risks of injury or death associated with the use of thousands of types of consumer products under the agency’s jurisdiction. Deaths, injuries, and property damage from consumer product incidents cost the nation more than $1 trillion annually. CPSC is committed to protecting consumers and families from products that pose a fire, electrical, chemical or mechanical hazard. CPSC’s work to help ensure the safety of consumer products – such as toys, cribs, power tools, cigarette lighters and household chemicals -– contributed to a decline in the rate of deaths and injuries associated with consumer products over the past 40 years.
      Federal law bars any person from selling products subject to a publicly-announced voluntary recall by a manufacturer or a mandatory recall ordered by the Commission.
      Source: Consumer Product Safety Commission
