DRZ450 Jetting
Let's see how many eyes that title attracts :) . Anyhow, I posted this over in the jetting forum, but I'd like a second opinion:
I've got the Millenium 450 kit on the way and would like to get a good starting point on the carb while I have all of this downtime. Here's the list:
'03 "S" model
450 big bore
Custom full Ti exhaust (Striker)
Hotcams in and out
FCR39 with JD kit
3x3 mod
Twin Air filter
I ride mainly around sea level with an occasional jaunt up in the mountains, perhaps around 5000 ft. It's really humid about 8 months out of the year. What's a good baseline? What normally is changed for larger displacement?
Jeez, it took 3 whole minutes for my question to get answered. You must be slipping :)
Thanks, B! :)
I am almost ready to assemble this beast, but need to clarify something. B-man, you said go two sizes smaller on main jet. I had a 160 and I threw in a 155, but I get this answer from James Dean:
The humidity and sometimes elevation will more often favor the red marked needle. Try the following-
Stock pilot jet
2 turns out on fuel screw
Red marked needle, 5th fron top clip position
#165 main jet (compare with a #160 to be sure)
Thanks,
James
Do you think that I should have had a larger jet in there to begin with? Do these settings sound good to go?
Well, if you would start with a 155, then I'll start with a 155. What about the other settings?
Red marked needle, 5th from top clip position
PAS?
