front number plate
i am taking my headlight assy off does anyone have an opinion of which number plate looks better. i have a 92 xr 250
I used the CRF450 plate with no modification. Looks like a factory install.
How did you attach it and did you put it over or under the front brake line routing? The way the XR4 is set up it seems like the brake line holder would get in the way of any type of number plate??
It goes under the brake line. You might have to bend the brake line guide. And you should use a vented number plate so the oil cooler isnt blocked.
Take off the old hardware that holds the brake line near the top. As you can maybe see in one of the pictures I had to use a piece of heavy wire (maybe 3" long) to attach the top of the plate to the top of the triple clamp 10 minutes work at the most. The half vent is perfect for our oil coolers.
http://www.imagestation.com/album/?id=4288469931
