Stock and BBR rims
I found my front tire was spinning on the rim from the braking force. Luckily I cought it before it put a hole in the tube. Since I was putting a more agressive tire on I drilled the rim for a rim lock since the stockers come with out one. Works great, I also heard from a friend that got the BBR rims that they come without holes for rim locks. I talked to BBR and they said to drill them too. Hopefully the new ones will come with holed drilled since I'm waiting on a set of blue ones.
If you keep getting a flat on the front try a rim lock on it.
you would think they would come pre-drilled but i guess not!! let us know how it works out for you when you get the rim!!
