Suspension help for '05 450
I have an '05 CRF450 and have a few suspension questions. At this point I only know enough to be dangerous. I weigh 155 and ride mostly mx at the expert level. I changed springs to 5.2 in the rear with 95 mm sag and .44 in the front with 395 cc of oil (I started with 385 but was bottoming too much). These are the recommended springs for my weight. The valving is stock.
Overall it works ok, but the front seems to chatter over small breaking bumps and the rear seems to kick on rebound. Fussing with the clickers hasn't helped much. I'm not really sure which way to go. Any of you suspension guys have any suggestions as to what direction to go? I think I need to revalve, but don't want to if I can fix it with clicker adjustment.
Any help is appreciated.
durkot,
Try posting on the "Suspension" forum, under technical forums. There are a few good suspension reps who chat there. You might get quicker responses.
Hope that helps,
--SAWDADDY
Who recomended to you that you go to softer springs?? even at 155 lbs (With out gear on) you sould be real close with the stk springs, especially if your riding at the A level . Most everyone over 180 goes to a 49kg fork spring with the stk rear. I recomend going back to the stk fork spring, I feel with a 44 kg front spring your front is riding to low in its travel and giving your bike a un-balanced feel, that is why your back end is kicking. (start with 385 also.) I hope this helps!! Troy
Ditto that...
Id have you put the stock springs back on there...
Thanks for the help. I was thinking that the front end may be down to far in the travel and that was causing the harshness in the front end. Like I said though, I know just enough to be dangerous and wasn't sure.
I will probably switch back to the stock front springs, but I will have to do something different with the rear. The reason I resprung in the first place is because I could not get the proper sag with the stock rear spring. To get to even 95 mm of race sag I had amost 50 mm of free sag.
I think I will try sticking with the softer rear and go to stock on the front and see if it the inbalance is too much. If so I will try something in between the stock and 5.2 in the rear.
I appreciate all the help. I don't know what a lot of us would do without this forum.
Well...hold on just a minute.
Stiffer springs will help to solve some of your problems, but it may introduce other concerns.
Let's cover some basic issues here before you jump to any conclusions.
First of all, the rear end of the bike will kick when the energy within the shock spring is released too quickly. In other words, the back end of the bike is moving forward and faster than the front end of the bike. Or you could say that it is "unloading" too quickly.
This is simply caused by not having enough rebound damping in the shock, or more specifically, the rebound rate is not in accordance with the spring rate.
Now, here's the tricky part. Sometimes when you introduce a rebound rate into a shock to keep kick from occurring, you lose other benefits. The biggest concern is the recovery rate - the rate in which the suspension can return the wheel back to the ground in order to serve its purpose. For the rear, the purpose is usually power delivery. If the rear wheel skips, you slow down.
The other consideration is the ability to load and unload for the purpose of hoping or seat bouncing the bike, which is not something that many riders need for trail riding but can be very advantageous for the tracks or a repeated terrain.
This means compromise, as are many things involving suspension setup.
Now the other issue.
When a shock or fork rides lower into the travel, usually because of a softer spring, there is a greater chance of the rider getting into a situation where the shock or fork can blow through the remaining travel, hence bottoming, which in turns introduces the situation of unloading too rapidly.
You can correct this in three ways. 1. Add more compression damping so that the shock or fork does not bottom, (as much) 2. Put in a stiffer spring, or 3. Add more rebound.
If you can't get within the proper sag parameters for the rear, a stiffer spring will only make matters worse. Therefore it becomes a matter of finding a good balance between compression and rebound damping and the level of flexibility you want with the bike with consideration to the terrain.
As for the front, you can only turn a bike by allowing the front to dive or by kicking the back end around (usually via the rear brake). If the front is too stiff, via the spring(s), the bike will push. Not a good thing considering a tight track.
On a four stroke, your need to manage the clutch in a corner is more critical than on a two stroke. You may at many times not have the option of kicking the back end around via the brake, leaving your turning demands on the issue of dive.
Now, softer springs in the front will also mean that the bike will ride lower. Not by much, but by some. The other issue with softer springs is the decrease of the "recovery rate" for the front end; something that becomes very very important when dealing with high-speed sections or whoops. In other words, what you want to minimize is to have the front wheel recovering when you're going into another bump. Imagine the effect of 31 lbs. of un-sprung weight moving in the opposite direction when it (and you) encounter the next strike. This has a huge effect on forward speed and rider fatigue, but it often goes undetected by most self-tuners.
With that, stiffer and softer springs will each have their benefits and down falls. In my opinion, and on my bikes, I run a rear spring that I can get 90 to 110mm of rear sag as long as I can remain within the parameters of the spring and shock design. I can do this with either a 5.2 of 5.4 at a rider weight of 170. I switch between the two for various tracks and other needs.
For the front, I run .44s, which is soft but it yields more benefits on trail and track than what I gain by running a stiffer spring. However, I run very little rebound in my forks and have my compression damping set at a rate (curve) that is right at the edge of...well, too much. This curve or rate causes the fork to ride a bit higher than what you get with factory settings, but still allows the fork to move into position before the apex of the corner. Additionally, I also switch between .44 springs that offer linear or non-linear rates (a long story but a worthy consideration).
The bottom line is to understand that spring selections are usually associated with ride heights and balance, and sometimes recovery rates, but should seldom if ever be considered to resolve excess oscillation, (movement). Whereas compression damping should be used to control compression rate and often bottoming, keeping in mind that a bike that often feels stiff and out of control is usually corrected by adding more compression damping. In other words, any suspension system that moves around more than the bump height is detracting from forward speed.
Hope this helps.
DaveJ
I bet your fork rebound (flathead screwdriver on the bottom of the fork) is set too hard/slow.
At your weight and ability I would use the stock springs front and rear, and 100 mm sag in back. The 5mm extra will help with the rebound (less stored energy in the spring to kick back), won't jar your teeth on the small stuff and still take the G-outs.
Put your rebound settings in the middle, front and rear, and go from there.
I agree, as I had similiar complaints with the stock springs at my weight - 175lb. I tried 95mm sag and it was unbalanced and overloading the front, making the small stuff chattery...reset to 102mm and it was better and the bike took a more level 'set' going into corners hard. I also went out one click on rebound in the front and the forks loosened up and tracked better over braking chop. If you are running the stock rebound with lighter springs it probably is too stiff on rebound. I'm also in two clicks on compression up front, as running it stock had the front hanging down too far and on fast 4th gear straights with chop it was too harsh..going stiffer made it plusher. I am getting it revalved though, as it can definitely be better than any setting I have tried.
As far as the rear rebound, I just need a revalve to get it right. At stock, 7 out, it is too fast and the rear end feels loose in sweepers with rolling bumps while hard on the gas, and won't 'set' and bite in. If I go in two clicks I can cure that and rail those, but then kickers on the face of jumps leave the rear feeling 'dead' and it doesn't recover fast enough in whoops making it harsh and kick. After testing two days and trying a lot of settings with rebound, LSC, then HSC I can't come to a setting I'm happy with all over the track.
Overall, the valving isn't bad until I start pushing it hard, and my novice friends think it is great at the last settings I reached, but I think at fast Intermediate speed or better it could be a lot better...the stock setup just isn't ideal for faster riders. My stuff is going to Factory Connection soon.
i know is sounds like blasphemy, but maybe you should check out the settings that mxa run. I know they can sometimes chat a load of bs, but they ride and race every week and have done for decades, so they really know all the bikes inside out. I think they recommend .49 springs, 375cc's of oil, and around 10 all round on compression and reboud both ends (2 out on high speed). I set it like that and it feels fine. I am 16 pounds hevier than you however.
Good luck man
Chris
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
