What's in the DRZ400S tool kit?
I recently bought a used '03 DRZ400s. It came with a small assortment of tools, but there's obviously some missing.
Can somebody post a picture or a list of the tools that come in the standard tool kit?
Thanks!
contents:
22 and 24mm single-ended wrenches for the wheels
10/12 and 14/17 double-ended wrenches
Spark Plug Wrench
Crappy black screwdriver with 2 reversible shafts
World's cheapest set of pliers
6" piece of conduit with one ended crimped (no idea what this is for??
i only carry the 22 and 24 and spark plug wrench on the trail
(and carry real tools for the other stuff)
contents:
Spark Plug Wrench
THANKS!!
BTW - crimped conduit is probably an "extension handle" for the axle wrenches.
IMHO, it doesn't really matter what all those tools are for b/c they all SUCK. ESPECIALLY the aforementioned pliers! Figure out what you need, then buy good ones.
Yea, what is that 6" conduit thingy?
It's a cheater bar. Slips over the end of the wrench for the rear axle nut to give you extra leverage. A very clever addition to the kit in my opinion.
I agree. Pretty much every motorcycle tool kit is for emergencies only. I usually replace the wrenches with better ones, add a set of vice grips, and adjustable wrench. My "multi-purpose" tool pretty much takes care of the other bits I might need. I also have a Motion Pro MP tool kit that supplements the OE tools well. I just wanted to know what the minamum tools were. Now I can add and/or replace what is needed or what's missing...
Sears here I come!
Sears here I come!
My bud works for Sears...kinda off topic here but didja know that they merged with Kmart? Maybe we can get some Blue Light Special Craftsman stuff in the future? :)
The only thing in the kit worth anything is the cool jointed spark plug wrench. The E does not come with a kit but I bought one off a guy who was parting out his bike just for the spark plug wrench. It also works on the front axles among other places.
Looking at leaving my home In Victoria BC Canada & ride to San Diego, CA Off-road If possible. What would you bring?
Edit: the bike has 12,000 miles on it. New Tires, Oil changed.
A cell phone is a very important tool to take with you on a ride....:excuseme:
I was thinking more in the lines of what to bring as a tool kit - ( tools to fix flat fire/replace tube/change out tire. Tools for oil chain, tools for broken chain!
I think you just told yourself what you should take....:excuseme:
I think you maybe correct, have you made a similar kit for your dual sport?
Forget that piece of crap, get a Cruz fender mount kit from Cruztools and swap the tire levers for a 22&24 mm combo wrench levers from DRC - wheelingcyclesupply.com
Best kit and best price on the market. I even picked up a spair at DealerExpo last yr.....
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
