Must Have XR Mods/Upgrades?
My XR is all stock. I know certain things that need to be done (pull baffle and snorkel), Uni Filter, and some sort of new silencer when the cash allows for it.
My question is: what modifications have you done to your XR that, now that you have it, you would regard as a necessity for every XR?
My plan is to eventually add a Uni Filter, fender-mounted tool pack, TrailTech Enduro computer, skid plate, new silencer, etc. Which silencer and skid plate do you reccomend? Should I look into a steering stabilizer as well?
Thanks! :)
Definately get some barkbusters.
Why would you need a steering dampner for an XR? I've never had any problems.
Yep. Barkbusters are on the list, as are Renthal bars.
As for the damper: I dunno, that's why I was asking. Saw some folks on here used them and thought they might have some insight on them.
As for the silencer I have tried two header silencer set ups. First the white brothers and then the big gun. The big gun killed the white brothers so I sold the white brothers.
For woods or trail riding a cheap mod is a 14 tooth gear :)
Once you remove your baffle and do the air box mod jets are pretty darn cheap too if you do them yourself.
If you do the air filter mod (Gordon's free mods) you can take that $$ and put it to wards one of your other items to buy. I have done the mod and see no reason to buy a new filter.
As for your tool bag, I made a very nice one for $1.00. I bought it at the dollar tree. I will add a few pics to show how to do it.
A free mod is to die some of the white plastic black with rite die. I died the chain giude, rear brak clamps and the mud/rock gaurd infront of the rear tire.
Cost under two bucks :)
My xr today is nothing like it was stock (03) and I really enjoy woods riding with the new and improved bike.
Check out my garage here at thumper and see some of the mods I have added, each one serves it's purpose and have added to power and performance.
Enjoy your xr and have fun with your mods.
yeah I know happens to me too if I don't oil after washing .........just couldnt resist :) .......you set yerself up for that one :p:)
yeah I know happens to me too if I don't oil after washing .........just couldnt resist :p .......you set yerself up for that one :):)
I had it coming
Gordon Mods and jet jet jet it...great stuff for low bucks. Just put a 426 kit in mine...not so low bucks, but I think I'm gonna like it.
The 426 kit cost as much as a muffler so keep that in mind. I just put my trailtech computer on tonight and Im going to test it out tomorrow. The trailtech has a light on it but it only stays on for like 5 secs. Thats kinda crappy but the rest of it seems cool.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
