question on forks?
i have some plus 1s for a crf50 and stock bushings make it so the forks dont go up or down. i saw that the plus ones are thicker in diameter. do you guys have any clue where to get the larger bushings or can i make the stock ones work?
there the same diameter as stock, and you DONT want stock bushings. if you have to use stock forks bushings are a MUSSSST!
what kind of forks???
all i know of is the same as stock for this exact reason. wherever you got the forks you need to get the matching bushings.
lemme guess.. homemade? :)
well looks like youll have to make them because sano stopped making them a long time ago. good luck
