making a 250f
This is like shooting fish in a barrel.
I would put the YZ250F motor in the RMZ/KXF frame with Honda suspension.
Aside from the valve problems the RMZ/KXF is an incredible handling package. Take the durability, high horsepower and plethora of aftermarket goodies available, the YZ250F motor is an easy choice. Add that silky smooth suspension from the CRF and that would be pretty tough to beat.
At least that's my wish list!
~Tex
'05 YZF
'04 RMZ
You are joking, right? The list is endless. Here is what I'd love to do...
1. Factory Connection suspension revalve. 2. Eric Gorr 262 high comp. kit. 3. Factory 4.1 exhaust. 4. Scotts stabilizer. 5. Big Gun head porting and polish. 6. ??? rev box. 7. Excel rims. 8. ??? brakes. 9. Hotcams camshafts. 10. IMS radiators. I could add another 50, but I also have a life other than TT. The really sad thing is that out of those 10, I only have 1. The Scotts stabilizer.
I would mold the frame out of titanium, as well as the footpegs (57mm), swingarm and I would get Renthal to make me a set of titanium TwinWall handlebars to come stock. Basically just make everything you can out of titanium or carbon-fiber and have Works Kayaba suspension, etc.
Doug
blue excels, red talon hubs, braking wave rotors, tag sprockets, did ert gold, akrapovic exhaust, black powdercoated swingarm and frame, black nitride forks... alright, Thats a lot of money...
actually it's just a lot of bling that has nothing to do with performance.
the poster asked for "the ultimate bike" but this sounds like "the bling-est bike".
jim aka the wrooster
'01 wr250f
pretty simple:
2005 bike
hi comp piston, stock bore
Works forks and shocks
gripper seat
DRd or Carbon Pro Exhaust
aftermarket chain/sprockets , bars/clamps
then ride it!
I am still waiting for someone to take the new YZ250 frame and stick one of the 4 strokes in it. That would be cool to see the future a few months early.
'01 wr250f
Isn't that what its all about? looking good out there...
What would you do about the oil resevoir???
If your "looking good" and going slow, its pointless. Why waste all that money on stuff that does absolutely nothing?
Doug
Oh, so I guess all that works suspension and motor work is going to make you squids go faster? just kidding... I would probably go ahead and throw in maybe an ignition and some big gun head mods, maybe some suspension to go with it. I don't want the ultimate engine unless I have a mechanic to rebuild it every couple months for me...
I personally find it funnier when the slow riders have all the suspension stickers all over their forks and shocks and talk about how they changed the compression 2 clicks for this track and so on... If someone is slow and just likes how a set of excel wheels looks on their bike, thats cool with me.
You can get wet-sump conversion kits for the F series. They are intended for racing use only since they cut the oil capacity.
Seriously for the 250f class.
CRF Bike with WR250F Motor Free mods +
1. 262 kit
2. Hot Cams
3. Custom Carbon Fibre tank, Glide plate, Sub Frame, Seat Base, Swingarm, Hubs and Rims
4. Renthal Bars + Dual Compound Grips
5. DrD Custom Carbon Pipe and Ti Header + mid pipe
6. 8 ounce lighter flywheel
7. Vortex X-10 CDI
8. Carbon Fibre Mag Cover, Clutch cover
9. Remove E-starter
10. Michelin S-12 Tyres
11. Tyre Balls
12. Magura Hydraulic Clutch
13. Goodridge Stainless Brake Lines
14. CRT Performance Stainless Steel Oil Filter
15. Twin Air Filter
16. RK Gold X-Ring + Renthal Alloy Sprockets with full range of rears and fronts.
Here goes: Personal WZ250F
YZ250F spec motor with electric start and 6 speed tranny (low first with a good top speed sixth, well spaced ratios)
Hydraulic clutch
Oversized radiators
Ohlins suspension
YZ plastic with slim and low approximate 2.8 gallon tank
FMF Ti Power Bomb w/ carbon fiber guard and TI Q muffler
Fasst Co Flexx bars with Rooster bark busters
Excel wheels with Rad hubs, Michelin S12 tires with Tire balls
DID X Ring chain with Sidewinder Tri Metal sprockets (afterall only can afford those things on a dream bike)
Good drilled light aluminum skid plate and frame guards
I would put training wheels on mine, so I could ride the bike. Of course, they would be clear plastic to give the illusion I am actually a good rider at a distance.
I would get a 05 and do this:
Motor:
Wiseco +.75 compressinon piston
PR2 engine work
FMF factory 4.1 Carbon
Magnesium clutch and ignition covers
Boyesen AP cover
Boyesen waterpump
Complete hinson clutch
Suspension:
ProCircuit Works showa suspension with the green/blue fork coating
RCS titanium shock spring
Chassis:
BBR perimeter aluminum frame
Carbon fiber guards
blue Excels
Renthal Twinwalls
RG3 trippleclamps
SDG seat
Decal Works T-1 graphics
Lightspeed titanium footpegs
