rear fender
I just picked up my 05 DRZ400s and i love the bike except for the Ugly rear fender! Has anyone just cut it off(up to the license plate) with a dremel? I tried a search on this forum but came up empty. Thanks!
I have seen some posts about this being done but not sure whether it was on TT or possibly the yahoo DRZ forum. Good luck.
I modified the entire tail-light assembly. Cut-off the bottom. Got rid of the entire spacer between fender and tail-light. Takes a little time but is worth the effort. Padded space between light and what was left of bracket with high-density foam for some cushion and weather-proofing as well as a silicone bead. Looks much better to my eye. And, got rid of a little weight. It positions the light higher which to my mind is not a bad thing. That Suzuki original tail-light assembly should get an industry award for being the ugliest SOB ever made. Good luck... :)
Got me a '05, the tail light assembly was the first thing to go! I used the baja designs LED tail light, with some arrow turn signals......it looks awesome, not sure if it is DOT approved, but catch me if you can! The tail light and the signals are very bright in my opinion.
One I figure how to post pictures, and actually take some, I will post......
You can either do a search, or click on the TT "store" button at the top of the page to see pics of the LED taillight/fender from Baja Designs. Ordered mine from the TT store earlier this week. That stock unit really is butt ugly.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
