04 CRF450 gold valve help
Just bought an 04 crf450 which Has gold valves front and rear. My problem is it was valved for mx and supercross. I want to use it in enduro's and require softer valving for the forks. this guy sent it out to be done and has no information for revalving. Can anybody pm me a shim stack config for it. I want to leave the standard springs in with really plush valving for rocks and tree roots. I don't have a code or anything for the race tech web site. I can do the valving myself but looking for a starting point.
thanks in advance :)
Where are the clickers set at. You may get what you wish, simply by setting the clickers different. I would try that first. Go softer on the comps front and rear, and see if you get your results you wished for. Another thing to try, is lower the outter chamber holds somewhat like 370 ccs or something. You can gain softer plushness by lowering the oil by 10 cc's. I did that and noticed a huge difference, but started bottoming on really large jumps. If you are not in danger of bottoming, I would definitely try those two things first, before getting into the shims. Good luck.
Thanks but I've tried the clickers and found that I can't get it where i want it, fussy in my old age, Havn't lowered the oil yet but that will mostly only effect bottoming at the end of the stroke. Need the plushness at the start of the stroke
Ok, sorry, thought it might be easy fix. I would say, if you have shims, the two largest one's in the stack need to be skinnier, but the same width as the one's that are in there. That will work on the light bumps. Second, make sure they actually are running cartridge fork oil. Some people like to put thicker oil in like 2.5 or 5 weight fork oil in. Cartridge fork oil is very thin like water. Lastly, yeah, mostly affects the large bumps, but I did notice a difference on the smaller one's as well by lowering the fork oil. I went down 10-15 cc's. Good luck.
Hey hows it going. I could help you out with the race tech work sheets. I have an 04 crf with gold valves. I'm a suspension guru. What is your weight? I can send you the information on valve stacks, springs and oil level. Only one problem i see is that if your bike has type 2 gold valves, they are designed for supercross. If they are type 1 you'll have better results. I have race tech recommended settings for 145lbs through 210lbs rider, with perfered soft and stiff settings.
Bikedude. that would be excellent :):p about 180 pounds in your lingo or 82kilos in ozzie talk. check your pm's and I will leave my email address It was set up mostly for mx so i would think they would be type 1
I have also a CRF 250 x and suspension like that but a bit stiffer would be excellent
Thanks again
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
