forks
I have also posted this in the suspension forum
Just bought an 04 crf450 which Has gold valves front and rear. My problem is it was valved for mx and supercross. I want to use it in enduro's and require softer valving for the forks. this guy sent it out to be done and has no information for revalving. Can anybody pm me a shim stack config for it. I want to leave the standard springs in with really plush valving for rocks and tree roots. I don't have a code or anything for the race tech web site. I can do the valving myself but looking for a starting point.
thanks in advance
Call RT and get ahold of tech support. Give them your weight and terrain type and they'll specify a more appropriate shim stack for you. You'll more than likely be removing some of the large shims and installing a two stage crossover shim to soften the valving.
