'05 DR 650 Speedo cable
Hello Folks,
I would appreciate it if someone could let me know where the speedometer cable connects on the '05 DR650Se (ie. front wheel, transmission, etc.). I would look myself but the closest dealer that has one on stock is 130 miles away. Why? I'm probably going to change the rear rim for tire options and don't want to make an adaptor box if I don't have to. TIA
Gary
yeah according to my manual the speedo gear box is on the front so you should be fine. :)
A 05 (i.e. a 03 when they went out of production) is the same as a 96- in most respects, and the speedometer cable should then connect to the front wheel hub.
/K
does any one know where i can find the little worm gear that rotate the cable to get the speed readout?? - its the little guy inside the box by the front weel
Thx.
Roy
