CRF450 Valve Clearance Calculator
my buddy has a 2004 CRF450, and we were checking his valves to see if they needed adjustment. One was just a little bit tight, so we had to figure out what size shim to buy.
We measured his existing shim, and from the formula in the manual, we were able to figure out what size shim would get him to stock specs.
He bought that shim, but he also bought one size smaller. We were curious as to what that would do to his valve clearance (how much looser than spec would we be?). However, being way bad at math, it took me like an hour to figure out what it would end up being (based on the formula in the manual).
So after I finally had the formula down, I made a quick web page here:
http://www.westsideridaz.com/ValveClearance
You can put in your current valve clearance, your current shim size, and the "what-if" shim size, and it will calculate the estimated valve clearance you would end up with as a result of the "what-if" shim size.
if this has already been done and way old info, sorry for taking your time. I thought it was pretty cool! Now we know what his 2.225 shim would do to his clearance (it would bring it to .30, which is on the loose side of spec, which is .28).
Let's not make this any harder than it has to be.
If your exh. clearance is .008, you need a shim .003 smaller to make it .011.
You need a smaller shim to increase the clearance.
If your intake is at .004, you need a shim .002 smaller to get it back to .006.
Each shim is one thousanth (is that a word) increment smaller or larger.
That calculator is cool. It is simple math, but it's alway nice to have a way to double check yourself before you order the wrong pieces/parts. :)
Here's something I put together a while back:
14901-MBB-000 .0472in 1.20mm
14902-MBB-000 .0482in 1.225mm
14903-MBB-000 .0492in 1.25mm
14904-MBB-000 .0502in 1.275mm
14905-MBB-000 .0512in 1.30mm
14906-MBB-000 .0522in 1.325mm
14907-MBB-000 .0531in 1.35mm
14908-MBB-000 .0541in 1.375mm
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
14921-MBB-000 .0669in 1.70mm
14922-MBB-000 .0679in 1.725mm
14923-MBB-000 .0689in 1.75mm
14924-MBB-000 .0699in 1.775mm
14925-MBB-000 .0709in 1.80mm
14926-MBB-000 .0719in 1.825mm
14927-MBB-000 .0728in 1.85mm
14928-MBB-000 .0738in 1.875mm
14929-MBB-000 .0748in 1.90mm
14930-MBB-000 .0758in 1.925mm
14931-MBB-000 .0768in 1.95mm
14932-MBB-000 .0778in 1.975mm
14933-MBB-000 .0787in 2.00mm
14934-MBB-000 .0797in 2.025mm
14935-MBB-000 .0807in 2.05mm
14936-MBB-000 .0817in 2.075mm
14937-MBB-000 .0827in 2.10mm
14938-MBB-000 .0837in 2.125mm
14939-MBB-000 .0846in 2.15mm
14940-MBB-000 .0856in 2.175mm
14941-MBB-000 .0866in 2.20mm
14942-MBB-000 .0876in 2.225mm
14943-MBB-000 .0886in 2.25mm
14944-MBB-000 .0896in 2.275mm
14945-MBB-000 .0906in 2.30mm
14946-MBB-000 .0915in 2.325mm
14947-MBB-000 .0925in 2.35mm
14948-MBB-000 .0935in 2.375mm
14949-MBB-000 .0945in 2.40mm
14950-MBB-000 .0955in 2.425mm
14951-MBB-000 .0965in 2.45mm
14952-MEB-000 .0974in 2.475mm
14953-MEB-000 .0984in 2.50mm
14954-MEB-000 .0994in 2.525mm
14955-MEB-000 .1004in 2.55mm
14956-MEB-000 .1014in 2.575mm
14957-MEB-000 .1024in 2.60mm
14958-MEB-000 .1033in 2.625mm
14959-MEB-000 .1043in 2.65mm
14960-MEB-000 .1053in 2.675mm
14961-MEB-000 .1063in 2.70mm
14962-MEB-000 .1073in 2.725mm
14963-MEB-000 .1083in 2.75mm
14964-MEB-000 .1093in 2.775mm
14965-MEB-000 .1102in 2.80mm
14966-MEB-000 .1112in 2.825mm
14967-MEB-000 .1122in 2.85mm
14968-MEB-000 .1132in 2.875mm
14969-MEB-000 .1142in 2.90mm
14970-MEB-000 .1152in 2.925mm
14971-MEB-000 .1161in 2.95mm
14972-MEB-000 .1171in 2.975mm
14973-MEB-000 .1181in 3.00mm
Nice to have hanging on the garage wall. RR.
I use that all the time. Thanks RR. :)
No problem Fred. Ol' ThumperTalk's a pretty cool place isn't it? :) RR.
Thanks for sharing. Appreciate the effort you put into the calculator, now I can check my "math" LOL
Ian
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
