Xr250l
Can anybody point me to an information source for a 1991-1996 XR250L? Have a chance to pick one up cheap and I would like to do a bit of research on it. Thanks
the most rescent would be a 95 if i'm not mistaking , i had a 93 , had alot of fun. Its a heavy bike nothing like a true XR. The suspension is very plush and if you start to want to trail ride this bike while trying to push it , soon the suspension gets wrapped up.
If you have suspension work done it then becomes more of a XR but with several lbs more.
I would say that if you are a seasoned rider
you can have some serious fun, for a beginner trying to do serious trail work its a bit of a dog.
You really have to anticipate with this bike like going over a diagonal wet log , the rake and trail is very different and the front wheel has a hard time to loft over obstacles without hammering it all the time.
I went over the bars tons of times with this bike
Good side it can be plated to toot around
bad side the stock motor is kind of whimpy. It can be made to do rather well, carburation and exhaust help is needed.
Valve adjusting is frequent l on these bikes , the cam is alot smoother than the stock XR.
If the price is right go for it, the nice thing with that bike is it has a real dipstick and you dont have to warm the bike up wondering if you have oil !
A place which had tons of part at the time was Thumper racing
stu
OK thanks,
I mainly wanted it because it's street legal and thought it would make a decent bike for my Wife to putt around on. Plus he says it has electric start which she'll need.
It may be pretty heavy for your wife to ride off road. I had a '96 for a while.
I don't think the US version came with a E start. Make sure on that.
That's what I thought too about the E start, But he says it has E start, although the starter is bad. WHo know? I'll check it out.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
