How many consecutive laps do you ride for practice
i can only get 4-5 laps before i am shot. i try to do this 3-4 sessions for a 20 lap day, 1 time a week. am i that bad of shape or do i need to tweak my stock suspension a little more. how many consectutive laps do you ride for practice?
john
03 crf450r
I can usually do 5-6 hard laps with an occasional glimpse of brilliance for a 15 laps or so, but I'm 34, about 5-10lbs over weight, and not in great cardio shape. In season I ride at least once a week - OHIO. This winter I've been doing the rowing machine every other day and I hope my stamina, not to mention my new 05 CRF, will help my staying power. :)
About the same as you guys. I tend to do more laps as the day wears on. I always do the most laps on my last session.
OT, how do you like that rowing machine panhandler? I've been tossing around getting one to break up the daily routine.
I think the biggest thing to enhance you riding stamina is more seat time. I'm like the rest of you guys only getting out 1-2X/week but I do work out, yet I still get arm pump, etc. I've also noticed that the more comfortable I am at a track, the longer I can go. I also noticed that when people are on me trying to make a pass, my arms cramp up. If I ride loose (i.e. don't death grip on the bars), I can usually at a pretty good pace for extended periods. So either relax or get a job that allows you to ride every day of the week. Just my two cents.
On our big, SX style track (average lap times 2:15-2:20) when I'm in shape I can pound out 8 hard laps before I'm toast. For training I'll do a 15-20 minute moto 2x. That's right about 8 laps +/- as well. . .
I love it, not hard on my knees like running and it's more total body. I got a cheap one - $250 MR900 Power Rower model#98900 from an online outfit. But its works ok for me.
Just to make everyone feel bad:
My son had a couple of his 15 year old friends over the house on Saturday to ride. Our track is about a minute and half lap times when it's dry. Saturday was muddy and those kids would go out and do 30+ laps at a time. For the day, they probably did 150+ laps. Heck, I can't walk for a week after doing 50 laps in a day.
If it is race day on a track I ride and know I will put in only about 4 laps.
I tend to doulble class and this gets me warmed up for the day.
I it is a track I do not have a lot of time on I may do 6-8 laps with the first couple feeling out some lines.
For normal practice days I will hit 4 practices and do about 12 laps each.
+40 nov.
I ride +30, and I generally go out for at least 8-9 laps at a time. Most of the time it is at least 20m+. I think the key is good suspension and bike setup. Getting the bike to fit you correctly. The other key is being smooth. Get out of control on a pinger and it isn't a problem. Do that with a 450 and there is a serious problem, it takes mucho energy to recover.
I work out about 2-3x per week, generally I run 2 miles on the treadmill then do a good top to bottom weight workout. I agree that seat time is key. But, I think bike setup and smoothness are also right up there.
Remember, sometimes you have to go slow to go fast. I see tons of guys on 450's that go into corners, square up and shoot instead of carrying speed and being smooth. Must be smooth, then you can get a ton more laps.
James
I can usually only do from 4-6 laps at a time, but we're talking about Englishtown here. The place is one of the roughest tracks around!!!
Here is what 4-6 of us do., The slowest starts first, then about 10-30 seconds the next one takes off, so forth and so on. The pro has to start behind me,.,lol And we turn a 30 minute moto. You wouldn't believe how that makes you push. Cause the guy infront of you don't want you to catch him and I don't want the pro to catch me, plus you have to pass people so it's fun.
Later
Adam
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
