carb id question
the carb on my used drz440e measures 42mm and has the # 29f40118 stamped on the side. Could someone id this carb? thx mlh
A few questions first: What year bike? Why do you call it a 440? Where did you measure 42mm?
I. D. No. 29F4 is a standard issue Keihin 39mm FCR carb used in the US and Canada on a Suzuki DR-Z400E.
A drz440 is a drz400 with a dope on the keyboard. I remeasured and the throat is 40mm on the engine side and 42mm on the air box side. I always thought they were the same. If you look into the air box end there is a narrowing ridge near the slide. The carb is a keihin and the bike year is 2001. It appears the coasting enrichment system has been taken off. When I rode cz's things were not as complicated. But, man is the ride different.
Thx to you and noble as well
Yup, that sounds like a standard issue 39mm FCR. Normally a carb is measured at the dia of the throttle plate (or wherever the manufacturer chooses). On a smooth bore FCR, that would be under the slide fully open. To be honest, I don't know what a 39mm FCR carb actually measures as often the published size is "descriptive" rather than "true" size. If the carb body has Suzuki numbers on it, which it does, then it came OEM on a Suzuki and would be a 39mm body.
thanks, the numbers after the 29f4 did not match any others when I searched. Now I can go the the jetting database and get started.
mlh
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
